cmshoot Posted May 17, 2009 Share Posted May 17, 2009 It's the large, black plastic, panel that is underneath the engine, you have to remove it to change the oil.. It's approximately 4' x 3', and is bolt to the mounts under the engine and the ground effects at the front. I'm looking to pick up a replacement and it would be way easier if I knew what the proper name was for it. Thanks Quote Link to comment Share on other sites More sharing options...
CA-Legal-Vette Posted May 17, 2009 Share Posted May 17, 2009 It's the large, black plastic, panel that is underneath the engine, you have to remove it to change the oil.. It's approximately 4' x 3', and is bolt to the mounts under the engine and the ground effects at the front.I'm looking to pick up a replacement and it would be way easier if I knew what the proper name was for it. Thanks The service manual calls it an "engine under cover." Not very technical. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 17, 2009 Author Share Posted May 17, 2009 Thanks! Need to get me a service manual. Quote Link to comment Share on other sites More sharing options...
CA-Legal-Vette Posted May 17, 2009 Share Posted May 17, 2009 Thanks! Need to get me a service manual. eBay is your friend! They are not cheap but then neither is Lexus service. I think I paid neighborhood of $60 for the manual but I also bought a CD from a guy for around $10. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 17, 2009 Author Share Posted May 17, 2009 I've bought several parts from ebay for my LS, I'll check for a service manual there as well. I've been all over the net and I'm striking out on the engine under cover. BTW, do you happent to know the pattern/pitch of the bolts that hold the engine under cover to the metal points under the engine? One of my mounting holes is buggered up and I want to run a tap through it to clean it up. Thanks for your help so far. Quote Link to comment Share on other sites More sharing options...
CA-Legal-Vette Posted May 17, 2009 Share Posted May 17, 2009 BTW, do you happent to know the pattern/pitch of the bolts that hold the engine under cover to the metal points under the engine? One of my mounting holes is buggered up and I want to run a tap through it to clean it up.Thanks for your help so far. No but I'll check later today and let you know. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 17, 2009 Author Share Posted May 17, 2009 Thanks! Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 17, 2009 Share Posted May 17, 2009 Lexus SHOULD send you a manual for free IIRC Parts.com for the best price on new OEM parts. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 17, 2009 Author Share Posted May 17, 2009 I have the owner's manual, I'm wanting the shop or service manual. Quote Link to comment Share on other sites More sharing options...
CA-Legal-Vette Posted May 17, 2009 Share Posted May 17, 2009 The usual bad news/good news thing The bad news. The under cover is attached using coarse threaded cap screw/bolts. They are pointed and has something like 10 threads per inch. The good news. I really don't think you need to run a tap through the holes. These puppies will clear them out nicely even if they are full of dirt. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 18, 2009 Author Share Posted May 18, 2009 Thanks. I'm missing a few, I'll try and pick 'em up at Lexus. Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted May 19, 2009 Share Posted May 19, 2009 cmshoot, if you haven't found toyodiy.com yet..... here you go: http://www.toyodiy.com/parts/p_U_199502_LE...EPGKA_5102.html It's too bad though, that screws are listed as just "STD. PART", but you do get a part number which will go a long way when contacting a dealer. Quote Link to comment Share on other sites More sharing options...
cmshoot Posted May 19, 2009 Author Share Posted May 19, 2009 Thanks! Quote Link to comment Share on other sites More sharing options...
