STALIN Posted May 9, 2009 Share Posted May 9, 2009 Hello! Not idle up, idle is down, when A/C compressor is on. A/C and engine trouble codes check - no errors, what is wrong? I encountered this problem after repair EGR pipe and starter. Thanks! Quote Link to comment Share on other sites More sharing options...
pfleyva Posted May 10, 2009 Share Posted May 10, 2009 From your photo I would guess that you have a 90-94. If so then you need to clean the throttle body. That will fix the idle. Quote Link to comment Share on other sites More sharing options...
