sarcilla Posted May 6, 2009 Share Posted May 6, 2009 I have a 2001 LS430 and I have reset the AC filter warning, but still need to change the filter. I ordered the filter and have it in-hand, but need to know how to replace it. Is there a panel at the back of one of the glove compartments? Just trying to save the $87 that the dealer wants to change it... Thanks in advance, Sonny Quote Link to comment Share on other sites More sharing options...
curiousB Posted May 6, 2009 Share Posted May 6, 2009 I have '04 so not sure it is the same. Mine is located in back of glovebox (front passenger side). There is a door in back of glovebox. Remove it (snaps no tools required) and then there are a couple snaps to remove the filter holder tray. The filter just sit in this tray and snap it back, then the cover and your done. 5 Minutes max. Quote Link to comment Share on other sites More sharing options...
craneauto Posted May 12, 2009 Share Posted May 12, 2009 I have '04 so not sure it is the same. Mine is located in back of glovebox (front passenger side). There is a door in back of glovebox. Remove it (snaps no tools required) and then there are a couple snaps to remove the filter holder tray. The filter just sit in this tray and snap it back, then the cover and your done. 5 Minutes max. The paper filter behind the dash should not trigger error code. There is a filter and descant bag inside of the condenser drier. If that is dirty and plugged, A/C will run very high pressure. I think that may trigger error code. Look at the A/C condenser from the bottom of the car, you will see a big plug which you unscrew. The descant bag new is WHITE color. Quote Link to comment Share on other sites More sharing options...
