How Do I Reset The Oil Maintance In My 06 Gs300?
I changed my own oil since its just easier and cheaper. And i followed the directions in the manual to reset the computer, but i cant get it to reset. Every time i turn on my car that alert message is there and its driving me insane. If anybody the correct way to reset set I'd appreciate it. Thanks
set the odometer mode to regular (total miles), not odometer A or B.
have your ignition switch in the all OFF. (turn off the car completely).
press and hold the odometer miles reset button AND (with your foot off the brake), press the ignition switch ONCE while still holding the miles reset button.
after 20-30 seconds, you should see the message saying your oil mileage has been reset.
good luck.
good luck.
hey man thank you so much. it worked perfectly.
