Strap, I just upgraded my foglights, on my 95' SC400. Once you get the splashguard down the foglight will be enclosed, with a circular plastic cap. I believe you turn it counter clock-wise to open the casing. This will give you access to the bulb and socket.
My problems began here, trying to disconnect the wire from the socket. The foglight wire fits snug into the socket. I had to wiggle and tug, until I jarred it loose.
NOTE *disconnect the wire from the socket before you open the clasp. This keeps the bulb in place and out of your way. To open the clasp, I believe you push down and it will unfasten. Hopefully it's
