Power Window Master Switch Problem
redranger
2004 RX330
I cannot operate the other windows while seated in the drivers seat. Each window works fine from its indiv control, just not from the drivers seat.
Recently changed battery. Any easy fix?
Hi RR...
This happened to me a while back when I had to get my battery replaced as well. Called the dealer and he gave me the following instructions: Go to each individual window, roll down and roll up, when you're rolling the window back up do not let go of the switch, keep pulling the switch up and remain holding it up for about 5 seconds after the window is shut. Do this on all the windows and it should reset the master switch.
Hope this helps :D
