tazanet Posted March 23, 2009 Share Posted March 23, 2009 hi all i have 99 es300 155k and i need your opinion! few month a go changed oxygen sensors bank1 bank2 and Camshaft timing oil control valve. did tune up 2 years a go. i always use 5w30 synthetic oil check engine light use to come only at hwy speed and disappeared shortly now I'm stuck with 6 codes 1153, 0100, 0110, 1349, 0505, 0420 last night engine had trouble to idle normally, hood was vibrating. its harder to brake in that case there is very small crack on air intake hose! can it be responsible to all this? im thinking of putting glue on hose, clean MAF sensor and IAC valve will reset battery and see if it triggers again my catalyst really rattles a lot but that's expensive part <_< P.S this is good site to look up part, diagram looks just like the dealers have. http://www.toyodiy.com/parts/g_U_1999_LEXU...20L-BTPGKA.html Quote Link to comment Share on other sites More sharing options...
tazanet Posted April 2, 2009 Author Share Posted April 2, 2009 oil control valve fix them all (1349) Quote Link to comment Share on other sites More sharing options...
