Replace Tail Light Bulb
donniebuchanan
I have 00 lx470 and need to know how to replace the rear tail light bulb in the lift gate
Open the tailgate and then you must unsnap the carpeted part. It's easier with two people as the plastic part that says "Lexus" has to be pulled up out of the way as it will spring back in place if someone is not holding it. Don't be afraid to pull on the carpeted part; it will snap back with ease. When it's off you will see where the lights are. There are three screws you must undo so you can take off the metal cover. Should be pretty easy from there!
Thanks
