Foot Well And Door Release Lights
I have an 07 RX350 and the foot-well lights and door-handle release lights are bright and then they dim once the car is started and the interior lights are turned on. Looking through a Lexus Electronic Service Manual it says that the Body ECU logic is to send less voltage for the dimming once a few criteria are met. They mention that the only setting you can change with these lights are with a Lexus hand-held tester and you can only turn the lights on/off as opposed to changine the brightness.
Does anyone know if there is a way to override this with some type of rewire so that those lights remain bright?
