Hi guys, I own a 1993 SC300 and have had a steering problem that needs to be fixed, hopefully someone can help me pinpoint the problem. When I turn the steering wheel either direction while driving, theres a delay in the respond time to the tires. It seems like its been getting worse over time and obviously its worse n more dangerous when I'm driving at high speed. Could it be my inner/outer tierods or something else?
id check the steerin rack see if theres any fluid in the boots, if so id think about replacing your steering rack, I had a similiar problem and I replaced the rack and Im good to go :P
your steering rack bushings are gone. daizen sells them for like 40 bucks online somewhere just google it. its explained here more: http://us.lexusownersclub.com/forums/index...sloppy+steering
thanks for the reply guys. Hey jzz30, I see your member information that you're form Hawaii, I'm on Oahu right now, I was wondering if its easier to buy them from you if you're still making them?
thanks for the reply guys. Hey jzz30, I see your member information that you're form Hawaii, I'm on Oahu right now, I was wondering if its easier to buy them from you if you're still making them? also where exactly is the bushings located?
