dudhi Posted February 18, 2009 Share Posted February 18, 2009 I noticed my coolant was getting low, so went and got the RED coolant from the dealer(He told me before 2003 should use RED). I just bought my 200 lexus es300 last year and can't tell if its using RED Antifreeze or not ( It looks pink to me but I am not sure about it). Question: Can I use my RED one (after diluting of course) in my car without flushing the other kind(if it is pink) ? (Just don't have time right now and its freezing cold out there) Will there be a problem if I mix the two ? TIA. Quote Link to comment Share on other sites More sharing options...
kingjack133 Posted February 18, 2009 Share Posted February 18, 2009 ...i don t think a 50/50 mix of red added would hurt anything, but i suggest you get the system flushed and filled next time you get a chance. Have the system pressure tested to find any leaks. I assume the coolant level went down due to evaporation. Make sure that is the case. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted February 18, 2009 Share Posted February 18, 2009 Starting with the 2002 model year....you should use the pink.....before 2002.....the Toyota red coolant.....you can't mix the two. Owners manual is your friend. ;) Quote Link to comment Share on other sites More sharing options...
