1993 Es300 Turn Signal Bulbs
margie b
HOW DO YOU REPLACE THE TURN SIGNAL BULBS IN A 1993 ES300. I'VE BEEN AT IT FOR OVER AN HOUR AND STILL CAN'T FIGURE OUT HOW TO GET TO THE BULBS!
Welcome to LOC margie :) I kindly ask you to take off your caps lock.....it's considered shouting at members.
Do you have the owners manual for your ES?
:cheers:
Most likely the front. Those are the ones ppl usually have quesitions about. If this is the case, you need to pull the headlight assemblies forward so you can access the turn signal bulbs from behind. There are three plastic tabs on each headlight assembly (left, right, and center) with screws through them which secure the assemblies to the body of the car. Remove the three screws on each and pull the assemblies forward, away from the body. Then you can get to the bulbs to replace them.
