Cold Morning Starts
pepa2000
maybe someone can help me so I dont have to take it to the shop. when the weather is cold around 15 degrees or below my ES 300 does not idle smoothly when I start it up it goes up and down very erraticly and sometimes it cant idle. when its 30 and above it idles fine. does anyone know whats going on? Thanks.......
  • 2 months later...
Hey there!
It is the TPS (throttle possitioning sensor), sometimes adjusting is enough, but I would recommend a new one. Visit your local store, it should be cheap cca 15-30USD.
Where it is? Open the hood, look at the "butterfly" - throttle valve, it is behind it, on the other side of intake pipe.
Do not remove it on yourself, do not even loose its screws. Ohm meter, socket for that TPS is needed and you need 0.70mm and 0.35mm thin pads to make it right.
Best regards.
