What is you experiences with the tire pressure sensor in the SC 430? Is it reliable or have you experienced malfunctions? My light is steadily on but the tires (run flats) have enough air.
How much air do you have in there? Also when temp drop your tire pressure will drop also. I would have your tires pressure around 35 psi. Once you go below 28 psi your light will come on.
www.jpimportz.org
