daly Posted December 10, 2008 Share Posted December 10, 2008 I have a 2008 LS460 want to put on my snows. Have a set of wheels and snows all set to go. Anyone figured out how to shutoff sensors so that it does not show up on dashboard? Quote Link to comment Share on other sites More sharing options...
Green Foot Posted January 20, 2009 Share Posted January 20, 2009 I was told the sensors are a part of the makeup of the actual tires. Therefore, if you detach the tires your car comes with, and attach special snow tires...it may take care of the problem automatically. Have you already tried and can't get the lights to go off? Or are you just assuming this will happen? Hope this helps. No expert by any means, just remembering what they told me when I bought the car. Quote Link to comment Share on other sites More sharing options...
reyoasian Posted August 31, 2010 Share Posted August 31, 2010 you can't. It's because your oem tires have tire pressure sensors inside, and if your vehicle is not gettin signal from that then your warning light will come up. there's prety much just 3 things u can do.. 1. get pressure for ur snows, which can be costly 2. put a black tape over the warning light so u dun see it everyday as it can be annoying 3. just ignore everything (which is what i do) Quote Link to comment Share on other sites More sharing options...
grognon Posted August 12, 2011 Share Posted August 12, 2011 Just buy new sensor on eBay as i did, they works great Quote Link to comment Share on other sites More sharing options...
reyoasian Posted September 19, 2012 Share Posted September 19, 2012 TPM are attached to the valves on the inside of the tire You CANNOT turn it off There are basically 2 things you can do: 1. Spend the money to have secondary set of TPM installed in your snow which cost $200+ 2. Ignore it! That's what I do. You shouldn't be relying on machines anyways, I always have my tire pressure checked once a week, summer or winter. As well whenever I'm home, my car will sense the TPM in summer tires in basement and warning would disappear Whenever I drove for maybe 20+ minutes, warning will come on again I just ignore it Quote Link to comment Share on other sites More sharing options...
LucasLutian Posted June 11, 2013 Share Posted June 11, 2013 Well in my opinion i must say that was informed that the receptors are an aspect of the cosmetics of the real wheels. Therefore, if you remove the wheels your car comes with, and connect unique snowfall wheels...it may deal with the issue instantly. Have you already tried and can't get the lighting to go off? . . baltimore car service | baltimore limousine service | limo service baltimore Quote Link to comment Share on other sites More sharing options...
Dasrakete Posted August 7, 2013 Share Posted August 7, 2013 I am not sure, if the chassis control module will recognize more than 4 tpm sensors. If it does then you can buy extra sensors for your snows. If not then it becomes a service trip to have the electronic brain recognize the new units. You will have to do this every time you change over from summer to winter tires. " Just ignore the light or go with the black tape". Quote Link to comment Share on other sites More sharing options...
