Power Steering Leak 97 Es-300
fixandfly
Great web site…
First Post
I own a 97 ES-300.
I have a power steering leak. I realize the ES-300 is front wheel drive and noticed the elaborate posting and great detail on the LS-400 but this is a rear wheel drive auto.
Over the weekend I sprayed and power washed the affected area and now clean I hope to notice where the leak is from.
On this auto should I expect the hose or the union fitting to be leaking?
Thanks
Fixandfly
fixandfly,
Your leak could be anywhere in the power steering system. I've seen cars where the steering rack needed new seals, the power steering pump needed new seals, and the high pressure hose leaked as well. You won't know until you get everything cleaned up and dry and then get the car running and in the air with someone behind the wheel. Then have them turn the steering wheel lock to lock while you search for the leak source with a flashlight. The most common leak source is the high pressure hose where the rubber hose is crimped to its metal ends, followed by the banjo joints (where the hose is fastened at the pump and the steering rack). Usually these joints just require new copper washers to seal the joints up. Anyhow, the replacement of parts is time consuming because of the cramped working space, but not above the average DIYer if you take your time. Good Luck and let us know how you make out.
