Suprasaurus Posted December 5, 2008 Share Posted December 5, 2008 Hi, I am trying to find out the stock injector size for the 3UZFE engine in a '02 GS430. Then I need to find injectors of the same impedance that are about 40-50% bigger. If anyone knows the capacity of the stock fuel pump, I need to know that too. I need to make sure there is enough fuel for 500 flywheel HP. I want to make about 350 at the wheels. I hope the transmission can handle that much. This is the beginning of a turbo project and before I start I need to make sure that it can be tuned. I don't think there have been very many turbocharged 430's so I know I have to find a lot of information. I tried to use the search engine to find this information but I came up empty. I may not have been using it right. Any help is, of course, appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
sakataj Posted December 5, 2008 Share Posted December 5, 2008 Hi, I am trying to find out the stock injector size for the 3UZFE engine in a '02 GS430. Then I need to find injectors of the same impedance that are about 40-50% bigger. If anyone knows the capacity of the stock fuel pump, I need to know that too. I need to make sure there is enough fuel for 500 flywheel HP. I want to make about 350 at the wheels. I hope the transmission can handle that much. This is the beginning of a turbo project and before I start I need to make sure that it can be tuned. I don't think there have been very many turbocharged 430's so I know I have to find a lot of information. I tried to use the search engine to find this information but I came up empty. I may not have been using it right. Any help is, of course, appreciated. Thanks. Good luck on this....keep us posted. i gotta run for a but i will c if i can help you with this info l8r...oh try using google for some of this info. i started looking into a turbo project when i bought mine and quickly abandoned it due to all the obstacles. started looking at a jet supercharger (u can check my old posts my 1st handful on these) but thinking bout going to the remote mount STS turbo now though. ttyl Quote Link to comment Share on other sites More sharing options...
