305pimpc Posted October 14, 2008 Posted October 14, 2008 has anyone had this problem before? it fires up fine and the when i drive off it starts to sputter i resete the codes and as soon as i turn on the car it turns on the check light 13 - RPM signal no. 2 This is the one that gives me the miss fire! 27 - Sub-oxygen sensor signal (on left bank) 29 - Sub-oxygen sensor signal (on right bank) The 27 and 29 are beacuse i have bad o2's and the car has an Exhaust leak by the o2's can anyone give me any ideas on what to look for??? p.c the car already had a tune up! cap rotors wires plugs iac valve i had a burned ecu and i had it fixed cause i couldnt find one!!! the car is super clean inside and out it has 196k on the dash its a 1992 LEXUS SC400 V8 1UZ-FE OH THE RPM TACH DOESNT WORK EATHERIT COMES AND GOES BUT I HAVENT SEEN IT ON IN A LONG TIME!!!!
305pimpc Posted October 15, 2008 Author Posted October 15, 2008 has anyone had this problem before? it fires up fine and the when i drive off it starts to sputter i resete the codes and as soon as i turn on the car it turns on the check light 13 - RPM signal no. 2 This is the one that gives me the miss fire! 27 - Sub-oxygen sensor signal (on left bank) 29 - Sub-oxygen sensor signal (on right bank) The 27 and 29 are beacuse i have bad o2's and the car has an Exhaust leak by the o2's can anyone give me any ideas on what to look for??? p.c the car already had a tune up! cap rotors wires plugs iac valve i had a burned ecu and i had it fixed cause i couldnt find one!!! the car is super clean inside and out it has 196k on the dash its a 1992 LEXUS SC400 V8 1UZ-FE OH THE RPM TACH DOESNT WORK EATHERIT COMES AND GOES BUT I HAVENT SEEN IT ON IN A LONG TIME!!!! THANKS EVERYONE! someone here w/b and told me to check the distrbutor wires that corode and give trouble so i when lookin and that was the problem it was grounding of and given me that code 13 so it fixed! ! ! ! ! thanks buddy im gonna find you and kiss you your the best thanks alot!!!! weeeeeeeeeeeee
plagadeon Posted March 7, 2012 Posted March 7, 2012 has anyone had this problem before? it fires up fine and the when i drive off it starts to sputter i resete the codes and as soon as i turn on the car it turns on the check light13 - RPM signal no. 2 This is the one that gives me the miss fire! 27 - Sub-oxygen sensor signal (on left bank) 29 - Sub-oxygen sensor signal (on right bank) The 27 and 29 are beacuse i have bad o2's and the car has an Exhaust leak by the o2's can anyone give me any ideas on what to look for??? p.c the car already had a tune up! cap rotors wires plugs iac valve i had a burned ecu and i had it fixed cause i couldnt find one!!! the car is super clean inside and out it has 196k on the dash its a 1992 LEXUS SC400 V8 1UZ-FE OH THE RPM TACH DOESNT WORK EATHERIT COMES AND GOES BUT I HAVENT SEEN IT ON IN A LONG TIME!!!! THANKS EVERYONE! someone here w/b and told me to check the distrbutor wires that corode and give trouble so i when lookin and that was the problem it was grounding of and given me that code 13 so it fixed! ! ! ! ! thanks buddy im gonna find you and kiss you your the best thanks alot!!!! weeeeeeeeeeeee Hello, I have a similar problem as you have had (=code 13). Could you please tell me what exactly is meant by: "distributor wires"? Which distributor is meant here? Thanks and best regards, plagadeon
