lexrx3 Posted September 8, 2008 Share Posted September 8, 2008 01 RX 300 71,000 - I've followed the instructions by others that had the same problem (remove servo, clean contact w/alcohol, redistribute grease) and it worked properly for an hour or two. Turned the car off and restarted later and the same problem occured. Only puts air through the main vents, a little through the floor now but none through the defroster. Is there any other solution other than buying a new servo? Will a new servo work properly and does anyone know if they've solved the problem or is it an overall bad design? Quote Link to comment Share on other sites More sharing options...
