lo0ol4me Posted August 28, 2008 Share Posted August 28, 2008 suddenly the volume in my car is gone !!, i can't hear any thing form radio , disk or caste after that i did another mistake, i unplugged the battery cable :( and that also made another problem. i only can use the driver windows ?? !!!! please help me :cries: Quote Link to comment Share on other sites More sharing options...
boB_2006_GS300 Posted August 28, 2008 Share Posted August 28, 2008 suddenly the volume in my car is gone !!, i can't hear any thing form radio , disk or caste after that i did another mistake, i unplugged the battery cable :( and that also made another problem. i only can use the driver windows ?? !!!! please help me :cries: the windows is a common situation. after you re connect power, you have to go to each door and cycle the window down and up a few times, and that will "train" the sensors to know to let the switch on the drivers door work properly. as for the radio, I had my "get confused" before and required me to restart the car, so you disconnecting the battery makes sense to me to trouble shoot. since that did not fix it, check fuses, and if you had connected any iPod or SAT radio adapters, check that the connections are tight. good luck, but at least you didn't screw up the windows :) Quote Link to comment Share on other sites More sharing options...
lo0ol4me Posted August 31, 2008 Author Share Posted August 31, 2008 suddenly the volume in my car is gone !!, i can't hear any thing form radio , disk or caste after that i did another mistake, i unplugged the battery cable :( and that also made another problem. i only can use the driver windows ?? !!!! please help me :cries: the windows is a common situation. after you re connect power, you have to go to each door and cycle the window down and up a few times, and that will "train" the sensors to know to let the switch on the drivers door work properly. as for the radio, I had my "get confused" before and required me to restart the car, so you disconnecting the battery makes sense to me to trouble shoot. since that did not fix it, check fuses, and if you had connected any iPod or SAT radio adapters, check that the connections are tight. good luck, but at least you didn't screw up the windows :) ====================================== thanks man i did what you told me about the windows , i fixed it :) but still the audio not running i got no volume control even if i go to audio in the screen it doesn't show me audio control when i start the car the audio system make sound like cable unplugged Quote Link to comment Share on other sites More sharing options...
