Diagnostic Code 15 ?
burgerman
Sure would appreciate some help on this. I hate to throw parts at this thing. Might this be an ignition control module problem?
Its possible that you may have bad #2 igniter, check to see if you have spark at the coil on top of the engine. If no spark check to see if the coil resistance if they are within spec: primary coil 0.36 to 0.55 ohm(cold), secondary coil 9.0 to 15.4 k-ohm(cold). Also check to make sure you have power to #3 terminal to the ingiter, which is the middle terminal, 9-14 v with key on or start postion.
Good Luck,
N.E.O.
  • 10 years later...
