brandon green Posted August 26, 2008 Share Posted August 26, 2008 I 'm searching for a wire harness so that I can switch out the factory nakamichi radio for an aftermarket cd player. I only see harnesses on ebay that are designed to use aftermarket radio ALONG with factory amplifier. If I use this harness, but do not use factory amplifier.....will the new radio turn on and work properly???? I know that the factory radio will not even come on without the factory amplifier. So what will happen? Is this the correct harness to use? I don't have the factory amp and would rather install an aftermarket amplifier with subs. Please help.....thanks. Quote Link to comment Share on other sites More sharing options...
