DKG Posted August 5, 2008 Share Posted August 5, 2008 What's up guys? I'm new to this forum. Just want to say hi Here is my concern. I have a 07 gs350 awd with ml. I want to upgrade my sound system to aftermarket speakers. So far, I figure my speaker sizes are: 6-1/2"(component), 1" (tweeter), 2.5" (possible add on bracket from factory, which should hold a 3-1/2" aftermarket speaker?), and 10" (sub) Correct me if I'm wrong with the above mention sizes. I want to use my factory nav system, but with the upgraded aftermarket speakers. What convertor would I use to change the system to run RCA lines? Also, will removing the ml amp cause any function problems with the nav functions? Basically, I want to gut out all the ml speakers and then add aftermarket speakers. I would be replacing the rear deck sub with an aftermarket sub and 2 more 10" subs in the trunk. Any ideas and recommendation would be great thanks Dave Quote Link to comment Share on other sites More sharing options...
electron Posted December 9, 2010 Share Posted December 9, 2010 What's up guys? I'm new to this forum. Just want to say hi Here is my concern. I have a 07 gs350 awd with ml. I want to upgrade my sound system to aftermarket speakers. So far, I figure my speaker sizes are: 6-1/2"(component), 1" (tweeter), 2.5" (possible add on bracket from factory, which should hold a 3-1/2" aftermarket speaker?), and 10" (sub) Correct me if I'm wrong with the above mention sizes. I want to use my factory nav system, but with the upgraded aftermarket speakers. What convertor would I use to change the system to run RCA lines? Also, will removing the ml amp cause any function problems with the nav functions? Basically, I want to gut out all the ml speakers and then add aftermarket speakers. I would be replacing the rear deck sub with an aftermarket sub and 2 more 10" subs in the trunk. Any ideas and recommendation would be great thanks Dave Hi, I am looking for factory ML speakers for Lexus GS. Are you interested to sell the speakers that you took off? Please let me know einhance@hotmail.com Quote Link to comment Share on other sites More sharing options...
pj8708 Posted December 10, 2010 Share Posted December 10, 2010 What's up guys? I'm new to this forum. Just want to say hi Here is my concern. I have a 07 gs350 awd with ml. I want to upgrade my sound system to aftermarket speakers. So far, I figure my speaker sizes are: 6-1/2"(component), 1" (tweeter), 2.5" (possible add on bracket from factory, which should hold a 3-1/2" aftermarket speaker?), and 10" (sub) Correct me if I'm wrong with the above mention sizes. I want to use my factory nav system, but with the upgraded aftermarket speakers. What convertor would I use to change the system to run RCA lines? Also, will removing the ml amp cause any function problems with the nav functions? Basically, I want to gut out all the ml speakers and then add aftermarket speakers. I would be replacing the rear deck sub with an aftermarket sub and 2 more 10" subs in the trunk. Any ideas and recommendation would be great thanks Dave Hi, I am looking for factory ML speakers for Lexus GS. Are you interested to sell the speakers that you took off? Please let me know einhance@hotmail.com Hi Dave, Just a quick note. The ML system has a very complex crossover system and just riping and replacing speakers that are not matched to the crossover network will probably not get you the results your looking for. Most of the time it is difficult to find an installer that will work on a Lexus if they have ever done it before. Paul Quote Link to comment Share on other sites More sharing options...
bkwindom84 Posted March 12, 2013 Share Posted March 12, 2013 You will need a summing device or digital sound processor. Look up audio source LC8 or there is an Aline unit that I hear is wonderful. You will be tapping into the wires after the ML amp so you will not compromise the stock system. Be careful with your power options as if you draw too much current from the car it will manifest itself in different areas as the car is mostly electronic be diligent with you research in that area. Quote Link to comment Share on other sites More sharing options...
Oaktribe Posted August 15 Share Posted August 15 Hello.. what is positive and negative on the 08 gs 350 woofer green and black wire? Thanks Quote Link to comment Share on other sites More sharing options...
