zygis Posted August 4, 2008 Share Posted August 4, 2008 My Lexus Rx330 starts to shake a lot when i start to go up the hill. Also it seems to loose power can it be differential problem? Quote Link to comment Share on other sites More sharing options...
Grumpa72 Posted August 4, 2008 Share Posted August 4, 2008 I assume that you have eliminated all of the fluid levels, tire pressures, and have no other symptoms? Is is possible that your tranny fluid is low? The other thing that comes to mind is a failing catalytic converter. I doubt that a 2005 has enough miles on it to worry about the cat but you should have it checked with a tail pipe emissions "sniff" because your symptoms sound vaguely like a clogged converter. Just random shots in the dark. Quote Link to comment Share on other sites More sharing options...
zygis Posted August 4, 2008 Author Share Posted August 4, 2008 I assume that you have eliminated all of the fluid levels, tire pressures, and have no other symptoms? Is is possible that your tranny fluid is low? The other thing that comes to mind is a failing catalytic converter. I doubt that a 2005 has enough miles on it to worry about the cat but you should have it checked with a tail pipe emissions "sniff" because your symptoms sound vaguely like a clogged converter. Just random shots in the dark. Thanks , thats exactly what i did they replaced 2 of them but i did not check the one under the car they only checked the ones coming from the engine. My tranny fluid is fine so the only option i have is to check the cat converter. I assume there are 3 cot converters? Quote Link to comment Share on other sites More sharing options...
