Kip Posted July 31, 2008 Share Posted July 31, 2008 I think I have a cooling fan problem. but I dont know how to trouble shoot it! My cooling fan is driven by my power steering fluid! Yet when not running I can spin the fan with no resiance! When running, I can bring the fan to a stop with my finger! Is this the motors problem, or does the fan have a fan clutch built into it?? Quote Link to comment Share on other sites More sharing options...
kingjack133 Posted August 1, 2008 Share Posted August 1, 2008 I think I have a cooling fan problem. but I dont know how to trouble shoot it! My cooling fan is driven by my power steering fluid! Yet when not running I can spin the fan with no resiance! When running, I can bring the fan to a stop with my finger! Is this the motors problem, or does the fan have a fan clutch built into it?? - its normal to easily stop the fan blades (with a finger) when engine running ....... minimal resistance . There are tests but they are not simple. 1. cooling fan ECU -under glovebox 2.coolant temp sensor(inlet, pass. side motor) 3.solenoid valve(rear of power steering pump) I would find someone who knows how to check these ,starting with the ones in the engine compartment first. Why do you think there is a problem with the fan? Quote Link to comment Share on other sites More sharing options...
Kip Posted August 1, 2008 Author Share Posted August 1, 2008 I think I have a cooling fan problem. but I dont know how to trouble shoot it! My cooling fan is driven by my power steering fluid! Yet when not running I can spin the fan with no resiance! When running, I can bring the fan to a stop with my finger! Is this the motors problem, or does the fan have a fan clutch built into it?? - its normal to easily stop the fan blades (with a finger) when engine running ....... minimal resistance . There are tests but they are not simple. 1. cooling fan ECU -under glovebox 2.coolant temp sensor(inlet, pass. side motor) 3.solenoid valve(rear of power steering pump) I would find someone who knows how to check these ,starting with the ones in the engine compartment first. Why do you think there is a problem with the fan? I replaced the radiator, both hoses, thermostat, cap, but it doesnt over heat all the time, so I figure its not the water pump, whats left? Quote Link to comment Share on other sites More sharing options...
kingjack133 Posted August 1, 2008 Share Posted August 1, 2008 when does it overheat? is the expansion tank(overflow resovoir) at normal levels when cold and hot? read the threads on es300 overheating probs? Quote Link to comment Share on other sites More sharing options...
