2003 Rx300 Lower Ball Joint Replacement
sleeke
Can someone share with me the estimated cost of replacement of a lower ball joint on a '03 RX300. I took it in for an oil change and Firestone is telling me that it needs to be replaced. I have had the car for 9 mos and have only driven 3000 miles. I travel for my job and have a company car. Is is necessary? What is a ballpark number I should shop around for. Thanks for any help! :)
PS. Mileage is 50K
While it is not normal for a ball joint to fail this early, things can and do happen. If this were my car, I would ask another mechanic to verify that the ball joint is indeed bad. I am not saying that the Firestone guy is trying to gouge you but I haven't heard of a modern ball joint failing that early. If you wind up needing this, I would guess that Firestone is capable of doing the job. What number did they give you?
Gary
