The Tach needle in my 1995 SC400 went out recently so I purchased a replacement meter online for $100. Turns out the meter I purchased is for a 1998 and the harness connectors are different between the 1995 and 1998.
My question for the board is this: Can I canibalize the meter from the 1998 to fix the meter on my 1995?
Thanks
  • 1 year later...
I'm bumping this back up to see if anyone feels like commenting. I've completely lost the tach and speedometer needles and will be tackling this project soon. There's a guy in Gilroy, CA that has replacements but he's asking $280 and as long as I've already spent $100 on the "98" I might as well try to use it.
I've done the easy part. I got the needles out of the "98". It was pretty painless. About 1 hour start to finish including cleaning up and posting this. Here's some photo's.
Poping the needles off was very much like popping the arms off a clock. The only difference here is the electrical connections. I will test the resistance in the needles before tearing into my guage. Hopefully, as long as there is some continuity, the needles will illuminate.
Sof far so good.
There are 4 clips that need to be pressed in order to seperate the halfs. Two on top and two on bottom.
Sof far so good.
I'm a idiot. You don't have to remove anything from the back of the guage. Just seperate the main body from the front (about 8 screws) and then pop off the needles.
