Alexander the o.k. Posted July 6, 2008 Share Posted July 6, 2008 One of mine: New Solar System Discovered Four Feet From Earth September 25, 1996 | Issue 30•07 PALO ALTO, CA—In what is being hailed as the most significant find in the field of planetary astronomy in decades, astronomers at the Palo Alto Observatory on Monday identified a new, previously unknown solar system approximately four feet from the Earth's surface. The system, located directly over nearby Van Nuys, is described as "a stable, elliptical binary system with at least four major planets, including two gas giants, an asteroid belt and several moons, approximately 17 million billion miles in diameter and some four feet off the ground." Though the global scientific community is still reeling from the magnitude of the Palo Alto team's research, efforts are underway to analyze the new planetary system using telescopic spectrographic analysis, as well as shovels, in gathering data from distances of up to 48.5 inches. http://www.theonion.com/content/node/30374 Quote Link to comment Share on other sites More sharing options...
Alexander the o.k. Posted July 7, 2008 Author Share Posted July 7, 2008 Report: 32% Of Prayers Deflected Off Passing Satellites March 19, 2008 | Issue 44•12 HOUSTON—According to an official NASA report released Saturday, nearly 32 percent of all prayers exiting Earth are deflected off satellites orbiting the planet—ultimately preventing the discharged requests for divine intervention from ever making it to the Gates of Heaven. "After impact with the satellite, these diverted prayers typically plummet back into the atmosphere, where they either burn up or eventually land, unanswered, in a body of water," the report read in part. "Of the remaining prayers, research confirms 64 percent fail to make it past the stratosphere because they aren't prayed hard enough, 94 percent of those with enough momentum are swallowed by a supermassive black hole at the center of the Milky Way galaxy, and 43 percent are eaten by birds." The report concluded that, of the 170 billion prayers issued last month, one made it to God, whose reply was intercepted by a hurricane and incorrectly delivered to a Nigerian man who reportedly did not know what to do with his brand-new Bowflex machine. Quote Link to comment Share on other sites More sharing options...
