Before you change the oil take the replacement filter into an auto parts store and buy a filter wrench that fits.
If you have the insert type with the permanent cannister try searching this site for the correct size. It should be the same as the one used on the RX350.
Assenmacher makes them. You might search this site for your specific application.
http://www.sjdiscounttools.com/asttoy640.html
