stanln Posted December 11, 2003 Share Posted December 11, 2003 cold start injector i need to know if anyone has done this job and is it hard to do , does anyone know where this is located on the engine . what i have read tells me it is in the manifold lexus dealer wants 700.00 , to do the job. sure could use some help . thanks Quote Link to comment Share on other sites More sharing options...
fiveofakind Posted December 11, 2003 Share Posted December 11, 2003 the cold start injector is attached to the underside of the air intake chamber, it is not attached to the intake manifold as you were lead to believe. Private message me with your e-mail address & I can send you the procedure for replacing it. Dont let the dealer do it. They will rip you off. If you are mechanically inclined, you can do this job. It will take some time thou. Be patient. What is your problem that you need to replace your cold start injector ???? Jeff Quote Link to comment Share on other sites More sharing options...
fiveofakind Posted December 15, 2003 Share Posted December 15, 2003 staln - need your e-mail address - if you want the procedure Quote Link to comment Share on other sites More sharing options...
