Do you have to be stopped to stitch into and out of power or snow mode. Or can I engage this will in cruising at certain speeds?
You can switch any time, but the transmission will not change modes until you accelerate. If you are in the 'normal' mode & change to 'power' while driving, the transmission will know that when you step on the gas pedal hard, you want it to downshift & hold onto that gear for a bit longer (more aggresive driving style). If you are in the 'normal' mode and you change to 'snow' mode, the transmission will not allow you to down shift and accelerate as aggresively. Same for upshifting - say you are at a stop & change from 'normal' to 'snow', it will automatically start out in 2nd gear & limit the power you can apply to the rear wheels. Same goes for switching from 'normal' to 'power' from a stop, if you hit the gas hard, it will keep 1st gear a bit longer than normal, then 2nd a bit longer etc....
i concur....... :D
"i will welcome myself back to the forum as im woo hooooooooo im finally unsuspended! hahaha!"
brian
