Battery Change Key Fob
1. Take out the mechanical key from your fob.
2. Put a flat head screwdriver into the inset space...just inside of the mechanical key slot....and turn it. This will pry open the fob.
3. Remove the old battery and replace with a new CR1632 battery..positive side facing up.
4. Replace the cover of the fob by first pressing on the bottom then the top (The top is the side where the mechanical key is inserted)
--Duckman
--Duckman
:D Thankyou Duckman for your reply. I need to order the batteries online, but that's not a problem.
  • 3 years later...
