Stiffer Spings Rate
Ben Ngiam
I have changed my stock suspension to Tein Comfort
Sports. I still find the suspension rather soft although much better than stock.
What stiffer spring rate should I change to? Currently it is :-
Front - 7kg//250mm
Rear - 6 kg/300 mm
I guess stiffer springs will compromise the lifespan of the coilover.
Thanks for your advice
Ben
  • 2 months later...
Ive also got the Tein CS and Daizen sways and I found it too stiff :D
I had to back the front damper off but leave the rear on max and is much nicer for me.
Do you have the Daizens? If you dont I would say get the Daizens instead of changing the springs.
