sherry97305 Posted May 21, 2008 Share Posted May 21, 2008 My '97 es300 has a slight lurching feeling when driving at speeds of 35mph to 45mph. I just had some engine work done, but they did not address this problem, as they said "They couldn't get it to do it". Could it be a problem with the transmission? It also lurches when I first put it in drive. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted May 21, 2008 Share Posted May 21, 2008 My '97 es300 has a slight lurching feeling when driving at speeds of 35mph to 45mph. I just had some engine work done, but they did not address this problem, as they said "They couldn't get it to do it". Could it be a problem with the transmission? It also lurches when I first put it in drive. miles on car? miles on tranny fluid? Last changed? Have you reset the ECM then driven? Quote Link to comment Share on other sites More sharing options...
sherry97305 Posted May 21, 2008 Author Share Posted May 21, 2008 My '97 es300 has a slight lurching feeling when driving at speeds of 35mph to 45mph. I just had some engine work done, but they did not address this problem, as they said "They couldn't get it to do it". Could it be a problem with the transmission? It also lurches when I first put it in drive. miles on car? miles on tranny fluid? Last changed? Have you reset the ECM then driven? 125,000. I just had it in for an engine oil leak. I'll find out about the tranny fluid. But, what is ECM? Quote Link to comment Share on other sites More sharing options...
