linda126 Posted April 27, 2008 Share Posted April 27, 2008 My son inserted the cartridge for my trunk mounted cd changer backwards! What is the best way to remove it without causing any damage? Quote Link to comment Share on other sites More sharing options...
gbhrps Posted April 27, 2008 Share Posted April 27, 2008 Oouch! Unless you are mechanically and electronically inclined, I would suggest taking the car to a car audio specialist who installs and repairs systems. They'll have to pull the interior trunk panels around the CD unit, unplug its wiring harness, disconnect the CD unit from the trunk floor, and then open the CD Changer case to see how the cartridge is binding in its receiving tray. Then they'll be able to pry and coax it out. Hopefully there won't be any broken plastic parts on the cartridge or bent metal sections inside the changer. There will be no way that the cartridge will be able to be powered out on its own. It'll have to be pulled from the changer, but it'll be best to do so with the case off so that you'll be able to see where it is jammed. Good Luck! Quote Link to comment Share on other sites More sharing options...
