The Big D Posted April 23, 2008 Posted April 23, 2008 What is the difference between the 6.1 Navigation System and the 7.1 Navigation System ? Is it just a Disk or is there a hardware change as well ?
amf1932 Posted April 27, 2008 Posted April 27, 2008 Aside from the newest mapping, there's a change in the firmware. You no longer have to push the "I Agree" button when you first turn on the Nav. You just get a "Caution" screen for about 5 seconds, and then the map comes up on the display.
tonystewart Posted May 28, 2008 Posted May 28, 2008 What is the difference between the 6.1 Navigation System and the 7.1 Navigation System ? Is it just a Disk or is there a hardware change as well ? Besides the map updates, there are alot of new POI's.
rhoag4147 Posted September 1, 2008 Posted September 1, 2008 Can you directly update from a Version 2/3 to 7.1????
Step Hen Posted September 1, 2008 Posted September 1, 2008 Can you directly update from a Version 2/3 to 7.1???? I think you are confusing the generation (2/3) of your navigation hardware with the most current version (7.1) navigation software. But the answer would be yes, you can upgrade directly to version 7.1 on your generation 2/3 system (doesn't matter your current software version).
arthurbeall Posted September 2, 2008 Posted September 2, 2008 Can you directly update from a Version 2/3 to 7.1???? I think you are confusing the generation (2/3) of your navigation hardware with the most current version (7.1) navigation software. But the answer would be yes, you can upgrade directly to version 7.1 on your generation 2/3 system (doesn't matter your current software version). Do you guys know anything about the non-OEM discs for sale : http://cgi.ebay.com/Lexus-Toyota-Navigatio...1QQcmdZViewItem Also, Is the dvd inside the nav system in the trunk ? Is it easy to replace ? Thanks! Art Beall
