Help With Bulb Sizes
Can anyone tell me what bulb sizes all the interior lights are on a '92 es300? I do not have the owner's manual and I think the sylvania website is wrong. I want to swap out the old ones and put it leds.
anybody know the bulb sizes or led equivalents?
The dome light behind the moon roof is a "festoon" type bulb. I know you can buy an LED equivalent that uses several small LEDs in a package the same size and shape. Not sure what type the map light is next to the moon roof buttons.
The bulbs in the front driver and passenger door panels are #194 wedge-base. Lots of LED options available for these. I just swapped those out myself and put in bright white/blue #194 LEDs from www.superbrightleds.com.....really looks sweet!
Thanks for the info, Lexucan.
What exact 194 wedge-base leds did you buy on superbrightleds.com? I know some are wider and/or larger depending on the amount of leds. Do the back passenger doors have the same size bulbs?
Do you know what size the festoon bulb is for the dome light?
The ones I bought for the front doors have only one hi-power LED per bulb
Superbrightleds.com P/N: WLED-WHP
This LED bulb is about as bright as the ones which incorporate 6 LEDs.
My back doors do not have lights in the door panels.
Sorry, I don't know the size of the festoon bulb for the dome light.
If you call your local Lexus dealership, they should be able to provide you with this info.
  • 3 years later...
The following lamp model application information is from my notes. While I can't guarantee it's accurate, I expect it is.
1992 LEXUS ES300
Instrument-general
Dome light
Trunk/Cargo area
194 (T5 base)
Front sidemarker
Rear sidemarker
Parking light
License plate
168 (T5 base)
High-mount stop light
921 (T5 base)
Glove box
74 (T1 base)
Map light
2040 (Wedge base)
Rear turn signal
Back up light
1156 (BA15s Single-Contact Bayonet base)
Front turn signal
1157A (Double-Contact Bayonet base)
Tail light
Stop light
1157 (Double-Contact Bayonet base)
Low-beam headlamp
9006
High-beam headlamp
9005
