130,000 Service
camlex
Hello,
On a 1MZ-FE engine (99 Toyota Sienna)that has 130,000:
I am going for a timing belt change. I am going to change the following: Please let me know what you think and add/subtract if needed.
1. TB
2. Crank shaft Seal
3. Cam Seals
4. Water pump
5. Thottle body clean (Change Gasket)
6. Idle Air Control Valve clean (Change Gasket)
7. Thermostat
8. Spark plug
9. Wire set
10.Fuel Filter
11.Spark plug tube seals
12.Hydrolic Tensioner Assembly
13.Idler pully assembly
Thanks,
