joed Posted February 27, 2008 Posted February 27, 2008 which coolant can replace Toyota/Lexus coolant? which break fluid? (Lexus uses SAE J1703 or FMVSS No.116 DOT 3) which power steering fluid? (Lexus uses Auto transmission fluid DEXRON II or III) which transmission fluid can replace Toyota Genuine ATF Type T-IV? if manager find this post is duplicated, pls redirect it to existing one that I failed to find.
Lexusfreak Posted February 27, 2008 Posted February 27, 2008 which coolant can replace Toyota/Lexus coolant?which break fluid? (Lexus uses SAE J1703 or FMVSS No.116 DOT 3) which power steering fluid? (Lexus uses Auto transmission fluid DEXRON II or III) which transmission fluid can replace Toyota Genuine ATF Type T-IV? if manager find this post is duplicated, pls redirect it to existing one that I failed to find. joed, all of the items you ask have been covered in the past.....please use the search feature in the future (try different word combinations if your not having any luck). I have sent you a PM with answers to your questions since we own the same model ES. Hope this helps. I am going to close this thread in an effort to avoid any possible 'fluid arguements' that have been occuring lately.
