Recommendations For Es300 '98
These are some recommendation I just received from my local mechanic:
1.Upper right "dog-bone" motor mount torn/worn out ,lower front and rear engine mounts worn out/loose
2.Transmisssion fluid leak at torque converter/pump seal area
3.Rear strut dust/splash boots torn
4.P/S leak at high pressure flex hose
5.Oil leak from lower timong area
Should I be concern?What repair of these I can postpone and what are urgent?
Thanks in advance. ;)
Oh,thanks.140000 miles.
1.You can buy the upper dog bone mount at autozone for $ 26.00 and do that yourself with a socket wrench, very easy.
2. The transmission leak, get it done asap.
3. COnsidering the mileage, you should just change the whole strut, this will come with new rubber boots that your mechanic said is ripped.
Hope this helps.
