Ls 430 Screen Problems
Sion
Hi, I was on vaction for a while and my car wouldnt start when i got back, so i had to obviously use jump cables to start the car. As my car started, it was running normally, but my on-board screen, clock and CD player seem to be all fused for some reason. Nothing works from that section. My car is an LS 430 2004 model. Do you know what the problem is? If it is just a fuse problem, do you know where it is in the car?
Thank you . Sion ;)
Thank you . Sion ;)
Take a look inside of your owners manual if you have one ;) Your fuse cover may also have a map on it telling you which fuse is which.
