dag19 Posted February 14, 2008 Share Posted February 14, 2008 I was just curious, without spending a ton of money, would it be worth it to add an amplifier and subwoofer to an existing Mark Levinson DVD Nav System? Is so, is there a better way than using a Line output converter? any help would be appreciated. Thanks Daroll Quote Link to comment Share on other sites More sharing options...
Brian Ross Posted February 16, 2008 Share Posted February 16, 2008 I used a line out convert on my '97 ES300 and the sound was surprisingly good. I tapped into the speaker line for the sub in the rear, which probably helped to eliminate the right frequencies when blending with the rest of the sound system. Quote Link to comment Share on other sites More sharing options...
boB_2006_GS300 Posted February 16, 2008 Share Posted February 16, 2008 I used a line out convert on my '97 ES300 and the sound was surprisingly good. I tapped into the speaker line for the sub in the rear, which probably helped to eliminate the right frequencies when blending with the rest of the sound system. I did too on my 06 gs300. first one (adapter) burned out. get a heavy duty one that handles a lot of watts. also get a class D amp (for sub woofers). they runs cooler. Quote Link to comment Share on other sites More sharing options...
