bmegdal Posted November 29, 2003 Share Posted November 29, 2003 I would like to change the tires on my 2003 LX470 from the stock 265/70-16 to some LT295-75-16's that I have from a previous vehicle. I know the speedometer will then be off, but on elocal shop told me I will have terrible problems with the fuel injection, check engine lite and ABS. Is this true? Quote Link to comment Share on other sites More sharing options...
bmegdal Posted November 29, 2003 Author Share Posted November 29, 2003 Must be wishful thinking...it is a 2001 LX470 that I want to put larger tires on. Thanks. Quote Link to comment Share on other sites More sharing options...
dougjohn Posted December 2, 2003 Share Posted December 2, 2003 Not true. You will have no problems with fuel injection, check engine light, ABS -- none of it. How the heck will the fuel injector know that you have bigger tires??? You might notice a bit of a loss as far as power goes -- but with the 470, it shouldn't be too bad. If you want to fix the speedo, you can get either a new spedometer gear or an electronic gadget (like the TruSpeed calibrator) to correct the speed on the spedometer. ... Doug p.s. I'm currently running 285/75 R16 and will probably get 315/75 R16 next, with no worries about EFI, ABS, ect. Quote Link to comment Share on other sites More sharing options...
