Hvac System Error 21
Tyler121
Just guessing but if you didn't have a light shining on the sunlight radiation sensor the diagnostic will stop there showing it as a failure. Holding a shop light above it usually gets you past that "fault".
From '92 LS400 shop/repair manual.
Code 21 is the solar light sensor ciruit.
22 is "locked" compressor.
23-30 not used.
31 is open/short in the reheat/remix damper position sensor circuit.
32 is open/short in the air inlet (fresh/recirc.) damper position sensor circuit.
33 [a] open in reheat/remix damper position circuit, or...
33 open/short in reheat/remix damper servomotor circuit, or....
33 [c] Remix/reheat servomotor "locked"/stalled.
34 [a] open in air inlet damper position sensor, or...
34 open/short in air inlet servomotor circuit, or...
34 [c] air inlet servomotor locked/stalled.
well i don't have a shop light but if i do it outside should it bypass 21? or do i need to go up to my neighbors and use his light
BRIGHT sunlight or flashlight....
What is your reason for testing...??
