James9969 Posted November 28, 2003 Share Posted November 28, 2003 I get 1993 GS300, There is some moisture inside left headlight, I was trying to take off to clean inside, After removing two bolts, I still can't take it out . Anybody has experience to remove GS300 headlight? Thx U in advance! Quote Link to comment Share on other sites More sharing options...
TouringGS Posted November 29, 2003 Share Posted November 29, 2003 Just got done through the same process on my '95 GS. There should be 3 screws holding a plastic cover on top of each headlight, remove those. Then there should be about 3 bolts holding each lamp in place, remove those as well. Then comes the pain in the !Removed!, which is removing 2 nuts (10mm I believe) vertically holding the outside corner of each lamp. To remove these, you'll have to go to the lining under the wheel arch and pull back the lining closest to the outer edge. You do have the option to remove the tire, but I left it on. The 2 nuts holding the lamp should be directly behind the lining. Good luck, and if you have any other questions just ask. Quote Link to comment Share on other sites More sharing options...
James9969 Posted December 1, 2003 Author Share Posted December 1, 2003 TouringGS: Thank you for your reply! I'll try tomorrow,. Quote Link to comment Share on other sites More sharing options...
TouringGS Posted December 1, 2003 Share Posted December 1, 2003 Hey, no problem. Let me know how it turns out. Quote Link to comment Share on other sites More sharing options...
