jam_nc Posted December 22, 2007 Share Posted December 22, 2007 Hi, I am trying to locate some visual instructions on how to change the cabin air filter on a 1997 Lexus ES300. The filter that I purchased has some basic instructions, however, they do not seem to match with my vehicle. Therefore, I am looking for additional information. I have pulled the carpet away (next to the accelerator) and exposed the cover to the filters. The instructions say to squeeze a tab at the top of the cover, and pull it out and away. I cannot locate this tab that the instructions refer to. Thanks. Quote Link to comment Share on other sites More sharing options...
camlex Posted December 22, 2007 Share Posted December 22, 2007 I am not the best to explain, but let me try. There's a one inch by five inch vertical strip that you see. That strip has two tabs on the top. Squeeze those two tabs and pull upward. The plastic cover will slip off after you squeeze the two tabs. Then remove the bottom filter. Pull that halfway and bend and pull the other half out. So now pull the other tab down, and repeat again. Pull that halfway and then bend and pull it out. Hope that makes sense. Quote Link to comment Share on other sites More sharing options...
Lextek1 Posted December 23, 2007 Share Posted December 23, 2007 It is possible that your car is not equipped. As I recall, not all ES's had the filter but if you do, the previous instructions are correct. If not, there will not be the tab to remove as he referred. Quote Link to comment Share on other sites More sharing options...
jam_nc Posted December 23, 2007 Author Share Posted December 23, 2007 I am not the best to explain, but let me try.There's a one inch by five inch vertical strip that you see. That strip has two tabs on the top. Squeeze those two tabs and pull upward. The plastic cover will slip off after you squeeze the two tabs. Then remove the bottom filter. Pull that halfway and bend and pull the other half out. So now pull the other tab down, and repeat again. Pull that halfway and then bend and pull it out. Hope that makes sense. Thanks. That helped. The instructions I received with the filter kit left out a step which caused some confustion for me. I was able to do as you described, and it worked like a charm. You definitely have to bend those filters at the mid-point junction to get them to insert (and come out) properly. Thanks again for your help. Quote Link to comment Share on other sites More sharing options...
catsigh Posted October 24, 2008 Share Posted October 24, 2008 For any others that hit this topic in a search you can find the information with pictures in the Technical Service Information Bulletin.pdf (TSIB) beginning on page 104 listed under "AIR CONDITIONING EVAPORATOR ODOR" . The PDF download is located in the forum sticky "1997 Es300 Factory Owners Manual". It also covers Models: ’92–96 ES 300, ’93–’94 LS 400, All GS 300, SC 300/400, LX 450. http://us.lexusownersclub.com/forums/index...showtopic=26428 "Cabin air-filter replacement" Quote Link to comment Share on other sites More sharing options...
