ktak Posted November 29, 2007 Share Posted November 29, 2007 I've found that on cold mornings, a strange clicking sound will come out of the instrument cluster. Almost like the clicking sound of the turn signal, but faster. It'll do that for a few seconds, then go away. Anyone have any ideas what may be causing this? It almost sounds like an electrical short, but there never seems to be any negative effects from the clicking sounds. Any help will be appreciated. Quote Link to comment Share on other sites More sharing options...
byf43 Posted December 3, 2007 Share Posted December 3, 2007 This sounds like a speedometer cable that needs lubrication. I'm not sure how to get to the cable, but, powdered graphite works great. Remove the cable from the back of the speedometer and 'dust' the cable and sheath, then re-install. Quote Link to comment Share on other sites More sharing options...
wwest Posted December 3, 2007 Share Posted December 3, 2007 I've found that on cold mornings, a strange clicking sound will come out of the instrument cluster. Almost like the clicking sound of the turn signal, but faster. It'll do that for a few seconds, then go away. Anyone have any ideas what may be causing this? It almost sounds like an electrical short, but there never seems to be any negative effects from the clicking sounds.Any help will be appreciated. Another thing that might make that sound is a servomotor's resistive positional feedback assembly, most likely a part of the HVAC, in the process of failing. Quote Link to comment Share on other sites More sharing options...
SRVCM Posted December 13, 2007 Share Posted December 13, 2007 Well I can tell you its not the spedometer cable as the instrument cluster is electronic and there is no spedometer cable attached to the back of the cluster. I know first hand as I have taken my cluster out from my 94 es300 several times Quote Link to comment Share on other sites More sharing options...
bhbingle Posted January 26, 2008 Share Posted January 26, 2008 So, I think I have this same problem. The noise is coming from just near the gas pedal up under the instrument cluster on my 95 ES300. So, I don't know what a servomotor resistive positional feedback is! :-l Can someone provide a bit more description so I can replace it? Thanks....Bart. Quote Link to comment Share on other sites More sharing options...
Donte Posted January 28, 2008 Share Posted January 28, 2008 I have the same problem on my '92. I noticed that it does it occasionally when the car is in drive but idle, like at a red light. I did notice though that while sitting in a drive-thru & I put the car in park it would stop but start again if I put it in drive and continue sitting still. The clicking also continued as I would push the gear knob in right before changing gears. Let me know if you find out anything. I just want to make sure it doesn't cause me to be stalled on the side of the road with both a 2 & 1 year old! :cries: Quote Link to comment Share on other sites More sharing options...
