Service Reminders
backyardmechanic
This may work.
Are you getting the OIL MAINT RESET message? If so, here's how to get rid of it:
1. Push the “ODO TRIP” switch in the switch box to
change the display to blank.
2. Turn the engine switch off.
3. Turn the engine switch on with the trip meter “RESET”
switch held down.
4. Keep pushing the “RESET” switch for longer than 7
seconds after the engine switch is turned on.
After the above operation, the master warning light comes
on, a warning tone sounds and the above message
appears to inform you that the engine oil maintenance
data has been reset.
How do I reset the oil change service message after changing the oil on my 2007 ES350, without having to go to the dealer?
Thanks!
That works...however...I recommend that you are in the THIRD mode of the IGNITION ON switch.
MODE 1 is OFF
MODE 2...after pressing the ignition switch (no foot on brake pedal) is "some" accessories
MODE 3...after pressing the ignition switdh (no foot on brake pedal) is all accissories
So,
Step 1, make sure you trip odomiter is displayed
Step 2, turn car OFF
Step 3, press and HOLD the trip odometer ( do NOT let go)
Step4, press the ignition switch TWICE
The trip odometer, after a few seconds will display 000000
You are reset!
