Lindatall Posted November 5, 2007 Share Posted November 5, 2007 I noticed a gasoline smell when I just took the car out. It's been fine the past couple of days. Anyone know what could be causing this and/or whether it's something I should look into. Quote Link to comment Share on other sites More sharing options...
skyfish400h Posted November 6, 2007 Share Posted November 6, 2007 I noticed a gasoline smell when I just took the car out. It's been fine the past couple of days. Anyone know what could be causing this and/or whether it's something I should look into. You ABSOULUTLY should not be smelling gas with the hybrid. They are designed to release as few unburned hydrocarbons as possible. It even pump out the fumes from empty tank before it will let you access to remove the gas cap. If you smell ANY gas fumes comeing from you hybrid, that's an IMEDIATE dealer vist. Are you sure it was coming from your car? Quote Link to comment Share on other sites More sharing options...
