When I approach the drivers door, and touch the handle only the drivers door opens. Can anyone tell me how to change the settings so that all of the doors will open?
This is taken out of the ES350 Owners Manual
Your vehicle includes a variety of electronic features that can be
programmed to your preferences. Programming of these features is
performed once at no charge, provided you obtain the service at the
30 day/1,000-mile scheduled maintenance service. Programming of your
Lexus Personalized Settings requires special equipment and may be
performed only by an authorized Lexus dealership.
My solution is if I need all doors open is to touch the rear door handle first.
Lexus Continues Personalized Settings for 2007 Model Line
09/12/2006 Torrance, CA
September 12, 2006 – Torrance, CA - All Lexus models for 2007 will continue to offer the complimentary Personalized Settings service that was launched across the model line for 2005. Depending on the Lexus model, the Lexus dealer can make up to 16 different adjustments to the electric and electronic systems on the vehicle. Settings that can be customized according to personal preference include interior lighting, window and moonroof operation, tilt steering wheel position and door lock control.
"Customer preference continues to be a top priority for Lexus," said Bob Carter, Lexus group vice president and general manager. "With Lexus Personalized Settings, we give our customer additional choices on how to set a vehicle's various convenience features according to personal preference."
At the time of purchase or lease, the Lexus customer is presented with a pamphlet describing all the possible settings that the dealer can adjust on the selected model. Examples include choices for how the power windows, moonroof and door locks operate with the remote key, and how the tilt and telescoping steering wheel responds when the engine is turned on or off.
In most Lexus vehicles, the tilt and telescoping steering wheel is set to move up and away from the driver when the transmission shift lever is placed in park and the ignition is turned off. This popular feature is offered to help the driver to move in and out of the vehicle with ease, but it can also be turned off by changing the setting so the steering wheel remains stationary.
The Personalized Settings feature offers several options for operating the power door locks and windows with the remote key. The standard unlock mode for most 2006 models unlocks all doors by pressing the UNLOCK button once on the remote. The customer can choose to have this setting changed so only the driver side door unlocks after pressing the UNLOCK button once, and then unlocking the rest of the doors by pressing the button a second time.
In the standard mode, all the power windows will roll down and the moonroof (if equipped) will slide open when the customer presses the UNLOCK button for 2.5 seconds with all doors unlocked. The customer can also elect to turn off this feature. The moonroof operation from the remote key can also be set to open when the UNLOCK button is pressed for 2.5 seconds and to tilt or slide according to the customer's preference.
Lexus Personalized Settings also allow lighting systems to be adjusted for added convenience. Cabin illumination can be adjusted to stay on for 7.5, 15 or 30 seconds after a door is closed. The length of time the headlights stay on once the ignition is shut off (with all doors closed and headlights in the ON or AUTO position) can be set at 30, 60 or 90 seconds. The customer may also choose to have the headlamps turn off as soon as the ignition is shut off and the driver's door is opened. In addition, the sensitivity of the automatic headlights can be adjusted to turn on under darker or lighter ambient light conditions.
On the RX 350 and RX 400h luxury utility vehicles, the customer can select different settings for how the power rear liftgate operates. For example, the standard setting for opening the rear power door is to unlock all doors first. If the customer prefers, this can be changed to allow the rear door to open without unlocking all the doors. In addition, settings can be adjusted for the back door buzzer's sound volume and number of beeps.
All programming of Lexus Personalized Settings must be completed by a Lexus Dealer and requires a special tool. The complimentary service is a one-time service available for up to 12 months from the date of purchase or lease of a new Lexus vehicle. Additional adjustments to Personalized Settings after the initial 12-month period can be made for an additional charge.
I need to get me that tool! :rolleyes:
this can be done by pressing the open button and close button at the same time and hold for about 5 seconds, you will hear a long peep. You can undo the change by repeating the same.
